No guarantees on this but as a workaround, try the attached lisp file and
dialog definition file to calculate the fill percentage of a conduit marker.
Feel free to modify this routine in any way. To use it you will need to load
the lisp file in AutoCAD and the dialog definition file, .dcl, will need to
be in an AutoCAD search path or you could enter the path in the lisp file.
Then at the command line enter calc_fill. This will look for your wire
information in the .WDW file and the conduit information in the .WW1 file.
If that information is found you will be asked to pick a conduit marker.
Once selected it will read the wire information off the conduit marker. It
will calculate the cross-sectional area for each wire based on its wire
diameter (pulled from .WDW file). It will add up these cross-sectional areas
and then divide it by the cross-sectional area of each conduit. And finally
multiply by 100 to get the %. Finally a small dialog will display with the %
for each conduit size.
So this calculation expects the wire diameter in the .WDW file and the
conduit's inner cross-sectional area in the .WW1. Feel free to modify this
calculation in any way you see fit. This is supplied as a starting point but
it should allow you to keep the wire diamter in the .WDW file so it is
correct in your reports..
Hope this helps,
Pat Murnen
"dns" wrote in message news:41506898_2@newsprd01...
> That explains why I get 214% fill for 15 #12 wires (d=.152") in 1" conduit
> (d=1.063"). What this math is calculating is only the linear diameter of
> all wires, and determining if it fits in the diameter of the conduit,
> which
> is definately wrong. What it should calculate is the sum of the
> cross-sectional area of all wires to determine if it fits in the
> cross-sectional area of the conduit. With the math currently used, only 7
> #12 wires would fit in a 1" conduit (100%). Just tabulating off a Code
> book
> shows that 19 #12 wires can be run in a 1" conduit, and that is
> maintaining
> a 40% fill (Required by code). Hope this helps. let me know if it's
> possible for me to modify the math in AE itself somehow.
> thanks.
> "Pat Murnen (Autodesk)" wrote in message
> news:414f2360$1_1@newsprd01...
>> I looked back to see the math used. It looks like it does a simple
> addition
>> of all the diameter values for the wires included in the conduit. Then it
>> takes that sum and divides it by the conduit diameter for each size and
> then
>> multiplies by 100 to get percentage.
>> conduitsize = pulled from .ww1 file for example 1";1.063
>> wiresize = pulled from .wdw file
>> wsum = sum of wiresizes for each wire in conduit
>> fill = ((/ wsum conduitsize) 100.0)
>> Any feedback you have on this is appreciated.
>> "dns" wrote in message news:414efcc5$1_1@newsprd01...
>> > any answers on Question #1? for the wire size, i mis-typed it in the
>> > post.
>> > it should be .0152, which is the value in the .wdw file.
> message
>> > news:41499a50_2@newsprd01...
>> >> I am going to hold off answering question #1 until I investigate a
> little
>> >> further. As far as question #2, you can reset this by selecting
>> > Projects ->
>> >> Extras -> Set Global Variable Value. Enter GBL_wd_wdwinfo and set
>> >> value
>> >> to
>> >> nil. This should force a reread of the .wdw file.
> news:4148d166$1_2@newsprd01...
>> >> > I have 2 questions/issues on the conduit sizing/report.
>> >> > 1. I can't get it to work right. I don't know if it's my input
> values
>> > or
>> >> > the math in cad itself. I just used as an example the wire size
>> >> > from
> a
>> >> > cutsheet and nominal conduit values off the NEC code. My
>> >> > default.wdw
>> > and
>> >> > .ww1 file located in ..\Autodesk\AutoCAD Electrical
>> >> > 2005\R16.1\enu\Support\User are as follows:
>> >> > default.wdw
>> >> > 12_XHHW;1.52
>> >> > default.ww1
>> >> > 1";1.063
>> >> > i'm getting a fill of 214% for 15 wires. Thinking that it must be
>> >> > cross-sectional area, and not diameter, i used .01815 for the #12
> wire
>> >> data
>> >> > which gives me a fil of 26% which sounds more reasonable. But then
> for
>> > my
>> >> > conduit report, the wire diameter is listed as .01815.
>> >> > 2. Is there a way to updated the project to recheck the .wdw and
> .ww1
>> >> file
>> >> > like the rebuild feature. Just to run the example above and change
>> >> > wire
>> >> > diameter in the .wdw file, AE doesn't seem to recognize the change
> when
>> > i
>> >> > re-run he conduit marker feature. I only affects it when i close
>> >> > out
>> >> > of
>> >> AE
>> >> > and re-open.
>> > message
>> >> > news:412e6e6e$1_1@newsprd01...
>> >> > > There are 2 support files that affect how this works. There is the
>> > .WDW
>> >> > file
>> >> > > and the .WW1 file. I've copied some info from the online Help that
>> >> should
>> >> > > explain how these work together.
>> >> > > The .WDW file contains the wire information. You may have a
> different
>> >> file
>> >> > > for each project. Simply create a projname.wdw file and put in the
>> > same
>> >> > > directory as your project file (.WDP). If you want to use the same
>> > file
>> >> > for
>> >> > > all projects, then create or modify the DEFAULT.WDW file in the
> USER
>> >> > folder
>> >> > > (use the Settings button on the Project dialog box to find the
>> >> > > full
>> >> path).
>> >> > > This file is a simple text file and can be edited with any text
>> >> > > editor
>> >> > such
>> >> > > as WordPad. There should be a separate line in the file for each
>> > AutoCAD
>> >> > > Electrical wire layer. The line has three fields, each field
>> >> > > separated
>> >> by
>> >> > a
>> >> > > semi-colon. The first field is the actual wire layer name used on
> the
>> >> > > drawing. The second field is the wire layer description. This
>> >> description
>> >> > is
>> >> > > used in the AutoCAD Electrical Wire Color/Gauge Label feature. The
>> > third
>> >> > > field is the wire size. (Note this third field is probably not in
> the
>> >> file
>> >> > > supplied with AcadE)
>> >> > > For example, you have a wire layer called 14_RED_THHN. When using
>> >> > > a
>> > wire
>> >> > > color/gauge label you wish the label to read #14AWG RED for this
>> > layer.
>> >> > The
>> >> > > wire itself has a wire diameter of 0.0087. The line in the .WDW
> file
>> >> would
>> >> > > read:
>> >> > > 14_RED_THHN;#14AWG RED;0.0087
>> >> > > The .WW1 file contains the conduit information. You may have a
>> > different
>> >> > > file for each project. Simply create a projname.ww1 file and put
>> >> > > in
>> > the
>> >> > same
>> > file
>> >> > for
>> >> > > all projects, then create or modify the DEFAULT.WW1 file in the
> USER
>> >> > folder
>> >> > > full
>> >> path).
>> >> > > editor
>> >> > such
>> >> conduit.
>> >> > > Each line has two fields. The first field is the conduit size that
>> > will
>> >> be
>> >> > > shown in the Conduit Marker dialog. The second field is the
>> >> > > conduit
>> >> size,
>> >> > > i.e. the inner diameter of the conduit, so AutoCAD Electrical can
>> >> > determine
>> >> > > how full the conduit is once you add up all the wire diameter
>> >> > > sizes
>> > from
>> >> > the
>> >> > > wires (pulled from the .WDW file). For example, you have a 1"
> conduit
>> >> with
>> >> > > an inner diameter of 0.5. The line in the .WW1 file would read
>> >> > > 1";0.5
>> >> > > So using the wire size and the conduit size the calculation is
>> >> > > made
>> > and
>> >> > > displayed. If there is no .WW1 file or is if the wire sizes are
>> >> > > not
>> >> > > in
>> >> the
>> >> > > file the calculations are not made.
>> >> > > If this still does not work, let me know and I will investigate
>> > further.
>> >> > > "Carl Smith" wrote in message
>> >> > > news:4113911f$1_1@newsprd01...
>> >> > > > In the Insert/Edit conduit/wireway label dialog box, there is a
>> >> section
>> >> > > that
>> >> > > > allows you to select the conduit size. The help mentions that
> ACADE
>> >> can
>> >> > > also
>> >> > > > calculate the % full for a particular conduit size based on the
>> > wires
>> >> > that
>> >> > > > are selected to fill the conduit. I am having trouble
> understanding
>> >> how
>> >> > > this
>> >> > > > works, can someone provide us with a little more information
>> >> > > > please?
>> >> > > > cds
