Right-click in a blank spot in the upper right part of your toolbar area. Select Electrical from the toolbar list. When the detailed list appears select ACE:Conduit Marker. Anchor this toolbar as desired. The first icon is for placing down a conduit marker. You can click on any line entity that is not a block and associate it as a conduit, for example a rectangle that represents a wireway in your panel. You can edit this conduit marker's tag, MFG, CAT and later define which wires are routed through it, all from the edit dialog screen.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
