AutoCAD Electrical Forum
components NOT SHOWING TEXTVALUES
2 REPLIES 2
acade2012
529 Views, 2 Replies
Hello All,
I am having an issue with inserting a component onto my schematic and the ratings not showing up.
In the look-up catalog under the textvalue is the desired ratings i.e.FUSE (RATING1=5.0 A;DESC1=CLASS "CC").
The ratings used to populate but have since stopped.
Is there a setting for this??
Both users here are having the same issue.
As stated above it use to work fine.
Any ideas??
Dennis
2 REPLIES 2
acade2012
in reply to: acade2012
FYI for anyone else having this issue.
I have found the cause of the issue.
I recently modified the access data base to include the company part number.
I added a column to the data base.
once I went back and removed the column it started to insert the text values again.
The column needs to be added to the end of the data base to work correctly
testsubject
Dennis,
Good catch. In all my years of using ACE I never added a column to the database.
Always learning something new...
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
”Boost
