I think you would want to set up to setup "user-defined attributes". Once
these are defined they show up as additional fields in the reports and can
be added using the Change Report Format.
To define attributes as "user-defined attributes" select
Projects->Reports->User Defined Attribute List. You enter the attribute
names and optional field names and length.
Hope this helps,
Pat Murnen
wrote in message news:5819886@discussion.autodesk.com...
We have data in the "Show/Edit Miscellaneous" fields and now want to use
that information in a table. I realize it will require a custom report; but
I cannot find the tag names that those lines are attached too.
I thought these tags were simply "DESC4," "DESC5," etc; but I cannot find
any tags like this under "Change Report Form" and I have tried multiple
report tabs and even multiply other tags.
Can someone help?
Thanks.
