AutoCAD Electrical Forum
Component Wire Numbering
8 REPLIES 8
Message 1 of 9
stanatgavan
1267 Views, 8 Replies
I want to be able to asign each end of a wire with the component name and terminal number IE: CR1-A1 AND TB1-1.
These numbers need to be positioned at the end of the devie they are connected to. I have used Nates otherend.lsp routine but this places NON-Intelligent text as wire numbers and assigns the number from one device to the end of the second device it is connected to.
This method is not giving me the results I need as indicated above. Also the replaceable parameters for wire numbers does not allow the specifying of the TAG1 or TAG2 values along with the Pin number of the given device.
Any Thoughts or suggestions???
8 REPLIES 8
Message 2 of 9
You won't be able to do this with automation, other than using something like Nate's lisp.  The purpose of a wire number is to identify an electrical node (a.k.a. network) by potential.  You can consider it a potential number to be precise.
Americans make use of this "wire number" primarily for troubleshooting purposes.  It allows a technician to test a circuit without removing wire duct covers to trace the wire physically.  So, the purpose of a wire number isn't to call out the connection of the wire, but the potential of the wire.  The panel shop connects the wires from component to component by referencing a wire From/To list.  They mark the exposed ends of the wire with the potential number so the technician who will later troubleshoot the panel will know that any wires marked with the same number should all measure the same potential, if using a voltmeter to test the circuit or an ohm meter to test continuity.
Having worked primarily with DIN and IEC standards myself, I can see both sides of the argument.  Europeans haven't typically marked wires with a potential number.  They mark the wire on the schematic drawings with the colour and size, and that's all, no wire/potential number.  They do not typically wire from a wire list.  Technicians who have risen through an apprenticeship program wire the panel using the schematic and panel layout drawings as a reference.  As they connect each wire, they mark it with the component ID (tag) and the specific wire connection (A1, A2, etc.) where each end of the wire will connect to its respective component.  The purpose of this type of wire ID is for component replacement.  When a failed component is replaced, the technician can connect each wire to the replacement component according to the markings on the wire label.
Having appreciated the advantage of both the American and the DIN/IEC style of wire marking, I have the panel shops print the wire labels with two lines, the first line contains the wire number, and the second line contains the component/pin ID (i.e. -1K12:K1 DIN/IEC or CR105:K1 JIC/NFPA).
With this background in mind, what I would like to see added to Electrical is the ability to generate a wire label report that contains both the wire number and the component tag/pin for each end of the wire.  Currently we have to copy and past the information from the wire list into the label maker software.
But to reiterate, the wire number itself should remain the same for both ends of the wire, since it is naming an electrical node, or potential.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 3 of 9
dshood
in reply to: stanatgavan
Does anyone have a lisp routine that will create a to from wire number based on the component designations/Terminals?
See sample Drawing file...attached
Dave
Message 4 of 9
vaimuthu
in reply to: dshood
any reply or feedback on this with AutoCAD Electrical 2015?
Message 5 of 9
rhesusminus
in reply to: vaimuthu
Still not possible to achieve this automatically with "out-of-the-box" AcadE 2015.
If you export the wire numbers to a spreadsheet, and create a from/to report in the report generator, and save this to a xls-file as well, Iguess you could get excel to do SOME of the work involved, and update the wire numbers in the exported wire numbers sheet. Then use import from spreadsheet to make the changes in the drawing.
However.. If a wire with a specific wirenumber is connected to several places.. should the wire number contain all these places it's connected to?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 6 of 9
BeiOh
in reply to: dshood
Did you finally find a solution for that?
Thx.
Message 7 of 9
rhesusminus
in reply to: BeiOh
AcadE 2018 has arrived. The answer is still the same.
Trond Hasse Lie
Ctrl Alt El
Message 8 of 9
ryoerger1
I would like to see the same functionality added to AutoCAD Electrical. I'm currently using the 2022 version of the software, and it does not appear to include it.
Message 9 of 9
rhesusminus
in reply to: ryoerger1
The same goes for release 2024...
Trond Hasse Lie
Ctrl Alt El
”Boost
