Hello all,
I am working on a project for work I have finished the print set for the client. However they have changed the naming convention they want for the comonents. Example: I have CR001 the client now wants 001CR, is there a way to change the component tags without going through the print set and editing each component ? Thanks for your help.
Solved by dougmcalexander. Go to Solution.
Solved by drathak. Go to Solution.
Solved by sonny3g. Go to Solution.
Yes, export the project to a spreadsheet. Change the tags there and then re-import the spreadsheet into the project. If you are not familiar with exporting to a spreadsheet and re-importing, I suggest you take a couple of minutes to read up on it in the AutoCAD help.
Good luck.
@Anonymous wrote:Hello all,
Easy, Change your project settings from %F%N to %N%F and do a project wide retag.
That is presuming you used automatic tagging.
@dougmcalexander wrote:
Drathak has instructed you wisely. After you change the project settings to %N%F, you will need to select all drawings using shift or CTRL and apply project defaults to these drawings. To do this, select the drawings, right-click over any one of the selected drawings, select Properties> Apply Project Defaults.
Ack! Forgot that step.
Been there and done that Drathak. Sometimes it takes more than one set of eyes. I appreciate you covering my back.
