AutoCAD Electrical General Discussion
Member
sdomke
Message 1 of 2 (276 Views)
Component Tag - Formatting Leading "0"s
276 Views, 1 Replies
11-06-2012 05:43 AM
I would like to format the %N variable of the Component Tag Format string to be at least two characters, placing a leading “0” in the event the %N value is a single digit.
The Component Tag Format set to “%F%S%N”
The problem I am trying to solve is best explained by this example:
A circuit breaker is placed on sheet 1, line 11. The resulting Component Tag is:
CB111
In a different project, a circuit breaker is placed on sheet 11, line 1. The resulting Component Tag is:
CB111
The result I am looking for is:
CB111 for sheet 1, line 11
CB1101 for sheet 1, line 1
If formatting the %N value is not possible, can anyone make recommendations for how to format the Component Tag to make it clear what sheet and what line number (or sequence) the device can be found in the print set?
Employee
jared.bunch
Message 2 of 2 (273 Views)
Re: Component Tag - Formatting Leading "0"s
11-06-2012 08:05 AM in reply to: sdomke
Hello sdomke
The %N is used as the variable when both sequential and reference based tagging are used.  If you are using sequential tagging, then you will need to make the starting number "01" rather than the default "1".  If you are using reference based tagging (with Ladders), then when you insert the first ladder you will want to make the starting number "01" rather than the 1.  There are also tools to renumber the ladder referencses if needed as well...
I hope this helps, but let us know if you have any more questions!
Jared Bunch
Principal Interaction Designer
IPG - AutoCAD Product Line Group
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
