AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Component Sub Assemblies
2 REPLIES 2
JMARSHALL1249
392 Views, 2 Replies
Is there any reason why bill of materials won't pick up sub assembly parts that are only stored on the secondary file.  We use a network file for the custom part numbers / sub assemblies and are unable to pickup subassembly part numbers, although the main part numbers are picked up without any problem.  When I copy the sub assembly code to my local drive, the parts list picks it up.  Is this an error or am I missing something?
Tags (1)
2 REPLIES 2
in reply to: JMARSHALL1249
I have the same problem, my catalog is on the network as a secondary.
You say you put a copy of the secondary code on your hard drive, where are those located at?
thank you-
Icemanau
Check the project settings for paths to the secondry catalog database.
If they are missing try adding them to the list to see if that works.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
