Hi There,
I would like to customize a Schematic Report>Components. So far I have defined the fields to be:
SH (sheet number)
REF (rung reference)
TAG (component tag)
DESC1 (device/reference arrow description.
I am trying to define it as:
SH (sheet number)
WIRENO (wire number at rung reference)
TAG (component tag)
The REF is not selectable in the Sort field of the report but I can live with that. I save the report as an Excel spread sheet where I can sort it, then simple copy/paste onto my I/O listing drawing. So far this seems to work well enough.
I would also like to include the wire number but I am doing something wrong. I add the WIRENO field to the Components Report just as I did the SH and REF field. The header for the WIRENO field appears in the report but the column does not have any data. I know the data is available because when I export the project to a spreadsheet I see a SIG tab that has a WIRENO column with the data I want in the Components Report.
This feature would be very helpful where my drawing shows a single component with multiple wires. I have arranged the drawing so there is a single wire and single reference arrow per rung reference. The goal is to show sheet/rung location, then the wire number(s) at that location no mater what they are connected to i.e. device or reference arrow, then show the description of a device and/or reference arrow.
What am I doing wrong with the WIRENO reference?
Of course this is leading to the next big thing, how to get the SIGCODE into my I/O listing or my Device Quick Reference list. All the info is in the exported spreadsheet, I just need to learn how to manipulate it.
The attached file is my custom components form configuration.
Thank you
