I am trying to number the components in ACAD E 2012 using the PLC address. The current format is %F%S%N. When I insert a component that is tied to the PLC, the component adds the sheet # also. Say I am on sheet 10 and I add a PB, it returns the number PB10I:0/01. What I would rather see is PBI:0/01 for the part #. If not on a PLC sheet, I do want to see the %F%S%N format. How can I change this?
Thanks, DD
This is part of the problem you get into when using the ladder style line references that merge the sheet number with the %N to create the complete line reference. If you want line reference 605 to mean sheet 6 line 05 it is best to use the default line reference style of numbers only and key in the sheet number as the first number of any new ladder's first line reference. This avoids confusion with cross-referencing, PLC tagging (PLCs default to PLC%N, not PLC%S%N) and would alleviate your problem as well.
We resolved this issue by setting the default properities for component and wire tagging to by %F%N only on sheets that were PLC modules all other sheets retaing the %F%S%N format. The ladder was still created with the %S%N format and the PLC module used PLC%S%N in the options. All other devices and wires that directly connected to the PLC module defaulted to the "Use PLC" numbering scheme.
Scott
