Use the 2nd+ (i.e. child) function to insert the light. Associate the light
to the appropriate pushbutton using the parent-sibling, drawing, or project
buttons. Next go to the parent/pushbutton and add the BOM data for the
light and any other "sub-components" using the Multiple Catalog button
(allows you to nest up to 99 additional parts with the pushbutton). If you
always use the same pushbutton/light combination you might consider setting
up an assembly code relationship in the catalog database.
wrote in message news:5769512@discussion.autodesk.com...
if I'm understanding your question correctly, you should be able to use the
"illuminated push button NO/NC" for your parent contact and insert the "2nd+
light" for your illumination. On insertion of the light you can
click the "project" button and select your push button contact from the
list. See the attached jpeg for a screen shot of the push button menu. You
shouldn't have to use custom components for something as simple as an
illuminated push button.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
