Hi Powerboss,
You mean that you enter a location value for the LOC attribute on this
symbol using the Insert/Edit dialog box but the attribute value you enter
remains invisible on the drawing? If so, the attribute is probably marked
invisible on the symbol. You can force it to be visible by selecting the
"Edit Attributes" toolbar button and pick on the graphics of the symbol (not
pick on an attribute of the symbol). A dialog will display and you can pick
on the LOC entry to flip it to "visible".
Let me know if this is what you are talking about. If so, then we probably
want you to edit the actual lib symbols so that the LOC attrib is always
visible.
Nate.
wrote in message news:5193953@discussion.autodesk.com...
NATE
I NEED TO EDIT BLOCKS HC01PJ AND HC01JP TO ONLY SHOW THE LOCATION CODE ON
THE DRAWING. I HAVE TIRED TO EDIT THIS SEVERAL TIMES WITH ANY LUCK. I WANT
TO WD DIALOG BOX TO OPEN AND PROMPT ME FOR THE LOCATION COME. CAN YOU
EXPLAIN HOW TO DO THIS?
THANKS
