One more option that would give you the commas and spaces is the Use Pinlist
order which is found on that same cross-reference dialog. If your project is
set up to use this option it will show these blank spaces for the unused
contacts so it can show the used pins in the proper order. To turn this off,
right click on project, pick Properties. Then pick the Text button in the
Cross-reference area. On the next dialog, select Sort by line reference at
the bottom. OK out of dialogs and then run the cross-reference on the
drawing again.
Pat Murnen
(Autodesk)
wrote in message news:4858919@discussion.autodesk.com...
The coil contact xref (NO NC) next to the coil is reporting wrong when using
a coil with a pin list (ex. SQD 8501RSD44M1P14V60 ). If I insert a NO
contact 1st then a NC contact next it xref's it as NO instead of NC. If I
insert the NC conact 1st it seems to work ok. It also displays funny showing
spaces and commas for unused contacts. This problem also exists on coils I
have entered into the database and created pin lists for.
