AutoCAD Electrical General Discussion
Valued Contributor
0 Kudos
Post 1 of 5
Close Project (API)
147 Views, 4 Replies
01-08-2008 08:09 AM
I would like to close a project (remove it from the project manager) through VBA (or lisp if VBA doesn't allow this). Is this possible?
Thanks in advance,
Jos
*Mike Spitzer \(Autodesk\)
Post 2 of 5
Re: Close Project (API)
01-08-2008 02:17 PM in reply to: Josdc
There is an undocumented lisp call that I believe will do what you want:
(ace_closeproject ProjectNameAndPath ReservedAlwaysZero)
ProjectNameAndPath - String containing the full name and path for the
project to close
ReservedAlwaysZero - Integer - Set to 0
Sample:
(ace_closeproject "c:/My Projects/Project.wdp" 0)
Since this is undocumented, it could change without notice in the future, so
be aware of that.
Mike
wrote in message news:5814939@discussion.autodesk.com...
Thanks in advance,
Jos
Valued Contributor
0 Kudos
Post 3 of 5
01-10-2008 01:53 AM in reply to: Josdc
Mike,
Thank you very much. This is exactly what I was looking for.
Jos
Valued Contributor
2 Kudos
Post 4 of 5
04-11-2012 12:51 PM in reply to: Josdc
Is there an update to this API call?  I can't seem to get it to work...
Valued Contributor
2 Kudos
Post 5 of 5
04-11-2012 01:06 PM in reply to: pjfontes
nm, you can only close a project if it's Not the Active project..
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
