AutoCAD Electrical Forum
Close Project (API)
4 REPLIES 4
Josdc
433 Views, 4 Replies
Close Project (API)
I would like to close a project (remove it from the project manager) through VBA (or lisp if VBA doesn't allow this). Is this possible?
Thanks in advance,
Jos
4 REPLIES 4
in reply to: Josdc
There is an undocumented lisp call that I believe will do what you want:
(ace_closeproject ProjectNameAndPath ReservedAlwaysZero)
ProjectNameAndPath - String containing the full name and path for the
project to close
ReservedAlwaysZero - Integer - Set to 0
Sample:
(ace_closeproject "c:/My Projects/Project.wdp" 0)
Since this is undocumented, it could change without notice in the future, so
be aware of that.
Mike
wrote in message news:5814939@discussion.autodesk.com...
Thanks in advance,
Jos
Josdc
in reply to: Josdc
Mike,
Thank you very much. This is exactly what I was looking for.
Jos
pjfontes
in reply to: Josdc
Is there an update to this API call?  I can't seem to get it to work...
pjfontes
in reply to: pjfontes
nm, you can only close a project if it's Not the Active project..
”Boost
