MY BASIC PROBLEM:
1) Somehow I get a mismatch between Panel and Schematic - not sure how/why it is mismatched
For example PB41700
2) I'm looking for an easy way to correct the mismatch once it is found:
-I suppose I can delete the panel part and re-insert
-I've tried changing ALL the part data in the schematic part (including mulitbom)
WHAT I'VE NOTICED
-Panel Exception report doesn't consistently report the problem (making it tedious for me to find & correct)
-Parent/Child update doesn't seem to work
details below
WHAT'S IN THE ATTACHMENT
-schematic dwg
-panel dwg
-3 panel reports
--before update run in schematic
--after update run in schematic
--after update run in panel dwg
--text listing of command window
AFTER FURTHER FIDDLING:
1) first I ran a Panel Exception report.
I noticed that there were mismatches between Schematic and Panel
(I ran the report while on the schematic page)
Panel/Schematic Exception Report ( all LOCs, all INSTs)
Report date: 10/30/2007 4:05:31 PM
Data Mismatch -------
PB41710 Mismatch CAT- Panel:E22B1, Schematic:E22JL2N8
PB41710 Mismatch DESC3- Panel:, Schematic:RED
PB41710 Mismatch DESC2- Panel:, Schematic:LINE/GLOBAL E-STOP
PB41710 Mismatch DESC1- Panel:, Schematic:SLITTER CAB
PB41710 Mismatch DESC2- Panel:LINE/GLOBAL E-STOP, Schematic:LINE/GLOBAL E-STOP
PB41710 Mismatch CAT- Panel:E22JL2N8, Schematic:E22BA11
2) Next, I tried Parent/Child update.
(As noted earlier, it doesn't properly process update file, I have to go to the project dialog and manually run the update)
3) next, I rerun the Panel Exception report
Still has mismatches
-seems to be saying that the PANEL DESC fields are blank
-it looks like it is listing CAT twice - I think this is because we have multibom (top plus 2 multi)
Report date: 10/30/2007 4:07:46 PM
4) Next, I go to the component on the PANEL drawing.
Run the panel exception report again
I GET DIFFERENT RESULTS
-it doesn't report any CAT errors
-now it says the Panel has DESC data, but the schematic part is blank
Report date: 10/30/2007 4:14:26 PM
Panel multiple Bill Of Material assignment, not on Schematic -------
PB41710 multiple Bill Of Material "01" missing
PB41710 Mismatch DESC3- Panel:RED, Schematic:
PB41710 Mismatch DESC2- Panel:LINE/GLOBAL E-STOP , Schematic:
PB41710 Mismatch DESC1- Panel:SLITTER CAB, Schematic:
TEXT WINDOW LISTING -----------------------------------------------------------------
Panel Component/Terminal query 36 of 36
Schematic 3
Report file written to C:\Documents and Settings\pmccutcheon\My Documents\AE
Problems\Exception Report
Command:
Command:
Command:
Command:
Select components to process
Select objects: 1 found
Select objects:
Extracting parent tags...
Extracting child devices/contacts... Processing parents
p
Updated CAT: --> E22JL2N8 (HPB22 @2.5,8.3)
Updated MFG: --> CUTLER HAMMER (HPB22 @2.5,8.3)
Updated CAT: --> E22JL2N8 (HPB22 @2.5,7.8)
Updated MFG: --> CUTLER HAMMER (HPB22 @2.5,7.8)
deleting records...
N:/ENG/ELEC/STR-11291/DRAWINGS/9-2-SLITTER/11291-9-2-417.DWG
N:/ENG/ELEC/STR-11291/DRAWINGS/9-2-SLITTER/11291-9-2-425.DWG
reading project database file...
reading......
2 pending changes written out to C:/Documents and
Settings/pmccutcheon/Application Data/Autodesk/AutoCAD Electrical
2005/R16.1/enu/Support/user/STR-11291-9-2.upd
No pending updates found in N:\eng\elec\STR-11292\BOM\STR-11292-9-2_rev1.xls
Command:
Command:
Command:
Command:
Checking drawing list for any marked in-use/read-only...
Command: wd_scr_msg "========== Drawing 1 of 1 =========="
Command:
Command: wd_scr_open_no_ro_chk
"n:/eng/elec/str-11291/drawings/9-2-slitter/11291-9-2-425.dwg"
_.OPEN
Enter name of drawing to open
Opening an AutoCAD 2000 format file.
Substituting [SANSS___.TTF] for [SAS_____.PFB].
Regenerating model.
Command:
Command: nil
Command:
Command: _.ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : _EXTENTS
Command: wd_upd_doupd_oem "C:/Documents and Settings/pmccutcheon/Application
Data/Autodesk/AutoCAD Electrical 2005/R16.1/enu/Support/user/STR-11291-9-2.upd"
"N:/eng/elec/STR-11291/Drawings/9-2-SLITTER/STR-11291-9-2.wdp"
Command:
Command: _.qsave
Command: wd_scr_msg "========== Reopening original =========="
Command:
Command: wd_scr_open_oksave
N:\ENG\ELEC\STR-11291\DRAWINGS\9-2-SLITTER\11291-9-2-417.DWG
_.OPEN
Regenerating model.
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Active project file:
N:\eng\elec\STR-11291\Drawings\9-2-SLITTER\STR-11291-9-2.wdp
Panel/Schematic Exception Report - Components
Select objects:
Schematic 3
Problems\Exception Report AfterParentChild Update>>
