AutoCAD Electrical Forum
changing Wire Numbers
3 REPLIES 3
chubby-1
145 Views, 3 Replies
when I insert a connection which is supposed to allow for wire number changes (6TB9) (reference line 2) when I go into edit the wire number on the left hand segment why does it NOT allow me to enter a new wire number, instead it defaults to "Fixing" the wire number on the right side segment?
am I missing something?
Marty
3 REPLIES 3
slrici
in reply to: chubby-1
If i understand what you are trying to do I think you may find that if you tried it on the next rung down where there is a component it would work.
If you are trying to place a terminal between the hot and common bus and run a wire from each to the same terminal that would be a short, and ACADE will not allow that unless you fix the wire number.
Not sure if that helps.
chubby-1
actually....what I am attempting to do is run a 24VDC wire into an upper connection of a terminal block, and run the 24V COM into a lower connection of the same terminal block. Think maybe I am getting into the "multi-level" terminal block issue.
I was under the impression I could do this, by inserting a terminal block and having the wires come in at different connection points on that terminal block. Do not think that is the case.
Thanks for the reply
Marty
slrici
I am not aware whether that can be done. I think I would try placing two Terms close together to depict that. Then the wires would be kept seperate.
However, I see that if you pick the Terminal like "Square with wire number change" and draw one wire through it horizontally and one through it vertically - a totoal of 4 wires - and then let AE number them, they are 4 different wire numbers. Maybe that is what you want, I am not sure.
Steve
”Boost
