AutoCAD Electrical Forum
changing wire color project wide
0 REPLIES 0
Message 1 of 1
testsubject
255 Views, 0 Replies
Has anyone found a good way to do this yet? I spent some time this morning searching and did not get anywhere.
I could always go through and rename the layers but that does nothing to the Wire Labels that are already on the drawing. So far I use "Change/Convert Wire Type" for each wire type I want  to change and then select all wires using a filter to get the matching ones. As you can guess, this is a little time consuming to have to do each drawing one at a time. It would be nice if this API would work project wide...
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
0 REPLIES 0
”Boost
