AutoCAD Electrical Forum
Changing the Terminal TAG-ID
2 REPLIES 2
testsubject
688 Views, 2 Replies
I know I am just missing something simple, but  how do you change a group of terminals Tag-ID on a schematic without using Find/Replace/Project Rebuild? I know I could change each one individually using edit terminal. Looking to change a bunch.
I am using ACE 2013.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
2 REPLIES 2
Icemanau
in reply to: testsubject
Go into the Terminal Strip editer and select the terminal strip that has the terminals you wish to change.
Select ALL the terminals you wish to change the ID on and then right click on one of the selected terminals.
From the list, choose terminals then REASSIGN.
Now just change the Strip ID as required.
Note that this is from the 2008 version, so it should still be available in the 2013 release, but you may have to hunt a bit for the commands
Regards Brad
Brad Coleman, Electrical Draftsman
testsubject
in reply to: Icemanau
Thanks Brad!
I knew it had to be something simple but I was just not seeing it.
Bob Hanrahan
Ace User since 1998
”Boost
