AutoCAD Electrical General Discussion
testsubject
Message 1 of 3 (339 Views)
Changing the Terminal TAG-ID
339 Views, 2 Replies
01-24-2013 01:32 PM
I know I am just missing something simple, but  how do you change a group of terminals Tag-ID on a schematic without using Find/Replace/Project Rebuild? I know I could change each one individually using edit terminal. Looking to change a bunch.
I am using ACE 2013.
Bob Hanrahan
Ace User since 1998
Go into the Terminal Strip editer and select the terminal strip that has the terminals you wish to change.
Select ALL the terminals you wish to change the ID on and then right click on one of the selected terminals.
From the list, choose terminals then REASSIGN.
Now just change the Strip ID as required.
Note that this is from the 2008 version, so it should still be available in the 2013 release, but you may have to hunt a bit for the commands
Regards Brad
Icemanau
Message 2 of 3 (334 Views)
Re: Changing the Terminal TAG-ID
01-24-2013 02:19 PM in reply to: testsubject
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
testsubject
Message 3 of 3 (318 Views)
01-25-2013 06:23 AM in reply to: Icemanau
Thanks Brad!
I knew it had to be something simple but I was just not seeing it.
Bob Hanrahan
Ace User since 1998
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
