AutoCAD Electrical General Discussion
Distinguished Contributor
0 Kudos
Post 1 of 2
Changing "base path"
85 Views, 1 Replies
04-30-2004 07:55 AM
Is there a way to change the "base path" that ACADE defaults to when you copy a project?
Chad
1 Kudo
Post 2 of 2
Re: Changing "base path"
05-03-2004 05:07 AM in reply to: fdna49
Chad,
You can set this in the WD.ENV file. Here is what my ENV looks like.
* Project and drawing-related paths and settings
WD_PROJ,v:/proj/,WD default project data
WD_PICKPRJDLG,v:/proj/,to override starting subdir for "PICK PROJ" button
In my case, "V" is a network drive so that all of our drafters have access to all of the projects. Any time we start a new project or copy an existing one, ACE points to V:\PROJ as the starting point. This path is also in our File Support Search Path under "Options".
Martin
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
