AutoCAD Electrical Forum
Changing "base path"
1 REPLY 1
226 Views, 1 Reply
Is there a way to change the "base path" that ACADE defaults to when you copy a project?
Chad
1 REPLY 1
MartinLee
Chad,
You can set this in the WD.ENV file. Here is what my ENV looks like.
* Project and drawing-related paths and settings
WD_PROJ,v:/proj/,WD default project data
WD_PICKPRJDLG,v:/proj/,to override starting subdir for "PICK PROJ" button
In my case, "V" is a network drive so that all of our drafters have access to all of the projects. Any time we start a new project or copy an existing one, ACE points to V:\PROJ as the starting point. This path is also in our File Support Search Path under "Options".
Martin
”Boost
