AutoCAD Electrical General Discussion
*Expert Elite*
testsubject
Message 1 of 8 (117 Views)
Changing Project Description Headers.
117 Views, 7 Replies
05-10-2004 11:45 AM
I am trying to change the Line 1, Line 2 Line 3, etc of the Project description to something more descriptive. It used to be that all I needed to change was a few lines in wdtitle.dcl but this does not exist anymore. What is the right file to use now?
TIA,
Robert Hanrahan
Bob Hanrahan
Ace User since 1998
Distinguished Contributor
rstein
Message 2 of 8 (117 Views)
Re: Changing Project Description Headers.
05-11-2004 04:28 AM in reply to: testsubject
You will need to create a file called ProjName_wdtitle.wdl and place it in the directory where your project file is located. ProjName = Same name as your project file. This file is a text file with a .wdl extension. within this file you will create the following:
LINE1=Description Line 1
LINE2=Description Line 2
LINE3=Description Line 3
etc....
Hope this helps
MartinLee
Message 3 of 8 (117 Views)
You have to use the default_wdtitle.wdl file. I've attached mine for your viewing pleasure.
*Jared Bunch \(Autodesk, Inc\)
Message 4 of 8 (117 Views)
05-11-2004 06:50 AM in reply to: testsubject
Testsubject In addition to Rob's recommendation, you can also make a default file rather than using the project specific. That file is setup the exact same way, it is just named default_wdtitle.wdl. This file is generally kept in the USER folder, but as long as it is in a location that AutoCAD Electrical searches it should be found. -- Regards, Jared Bunch Technical Support Specialist Autodesk, Inc "RobStein" wrote in message news:14969548.1084274973990.JavaMail.jive@jiveforum1.autodesk.com... > Hi, > You will need to create a file called ProjName_wdtitle.wdl and place it in the directory where your project file is located. ProjName = Same name as your project file. This file is a text file with a .wdl extension. within this file you will create the following: > > LINE1=Description Line 1 > LINE2=Description Line 2 > LINE3=Description Line 3 > > etc.... > > Hope this helps
Message 5 of 8 (117 Views)
05-11-2004 06:53 AM in reply to: testsubject
Testsubject Sorry for the duplicate answer! It looks like Martin already had you taken care of. It appears as the not all of the messages are getting through to the Outlook Express still in comparison to the Web-based. -- Regards, Jared Bunch Technical Support Specialist Autodesk, Inc "RobStein" wrote in message news:14969548.1084274973990.JavaMail.jive@jiveforum1.autodesk.com... > Hi, > You will need to create a file called ProjName_wdtitle.wdl and place it in the directory where your project file is located. ProjName = Same name as your project file. This file is a text file with a .wdl extension. within this file you will create the following: > > LINE1=Description Line 1 > LINE2=Description Line 2 > LINE3=Description Line 3 > > etc.... > > Hope this helps
*Expert Elite*
testsubject
Message 6 of 8 (117 Views)
05-11-2004 08:47 AM in reply to: testsubject
Thanks for the info. That file did not exist so I created one in the Support folder and now I have the descriptions I want.
Robert Hanrahan
Bob Hanrahan
Ace User since 1998
amt_controls
Message 7 of 8 (117 Views)
11-17-2004 05:19 AM in reply to: testsubject
I have AutoCAD Electrical 2005. I cannot find this file. Has it changed?
rstein
Message 8 of 8 (117 Views)
11-17-2004 05:47 AM in reply to: testsubject
The file does not exist you will need to create a text file with a .WDL extension
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
