See if this little utility works on 2004. You pick the balloon bubbles you
want to "inflate" by your entered ratio. It should make the ITEM number
bubble/text bigger but leave the leader/arrow the same size.
You'll need to APPLOAD this utlity. Then type "inflate" at the command line
to run.
; ** 06-May-05 NEHolt created as example
(defun c:inflate ( / ss en ratio save_sysvar_pickstyle ed ent_type ent_name
xy inflation_ratio)
; "Inflate" AcadE ITEM number balloons
(if (setq inflation_ratio (getreal "Balloon inflation ratio (1.0=no
change):"))
(progn
(setq cancel nil)
(while (not cancel)
(if (= (logand (getvar "PICKSTYLE") 1) 1)
(progn ; GROUP selection mode is "ON", need to turn it off so that
user pick
; on balloon bubble doesn't grab the leader lines as well
and complicate
; the program.
(setvar "PICKSTYLE" 0) ; turn off GROUP mode
(princ "\nNOTE: GROUP mode termporarily turned OFF. Hit
CTRL+SHIFT+A to restore GROUP selection mode.")
(setq ss (ssget ":S")) ; prompt user to pick one item
(if (= ss nil)
(setq cancel 1) ; flag to exit
; ELSE
(progn ; Figure out what what picked. See if it is an AcadE
"balloon" block insert
(setq ent_name (ssname ss 0)) ; get first/only picked entity
name from selection set
(setq ed (entget ent_name)) ; open the entity
(setq ent_type (cdr (assoc 0 ed))) ; extract entity type
(if (/= ent_type "INSERT")
(progn
(princ " ?? ")
(princ ent_type)
; ELSE
(progn ; user picked on INSERT, see if carries attribute
B_ITEM
(if (not (c:wd_getattrval ent_name "B_ITEM"))
(progn ; doesn't appear to be an AcadE balloon
(princ " not an AcadE ITEM balloon ??")
; ELSE
(progn ; okay, user has picked on AcadE ITEM balloon.
Prepare to scale it up.
(setq xy (cdr (assoc 10 ed))) ; save balloon block's
insertion point
(command "_.SCALE" ent_name "" xy inflation_ratio)
(setq ss nil) ; release selection set
(princ)
wrote in message news:4835753@discussion.autodesk.com...
We are using ACE2004. Is there any way to change the size of the BOM text
and bubble for items that have already been called out short of changing the
settings and retagging everything? We draw our panels in model space and
place our borders in paper space with a scaled model space window for our
panel layouts. Sometimes when I open up the model space window, I find the
BOM text/bubbles are too small to read depending on what scale I set my
window too. Any suggestions out there?
