amt,
When you scale the drawings you may have to go in and move the X?TERM?? wire connections to the locations they need to be to reline up with the other scale that you are using. This is really apparent when there are vertical termination points.
For example, if the original part had two termination points that are located 1" vertically from each other, then after scaling by .75 they will be .75 apart from each other. You would need to move them both equally apart to put the points back to the proper 1 " apart value(i.e. move one up .125 and one down .125).
This also holds true for insertion point. If you do not pick 0,0,0 as your reference scale point then the insertion point will be off after scaling.
All the drawings supplied in ACE have a reference point of 0,0,0. It would be in your best interest to continue with this. Trust me. It will help you later when something does not line up right during an insertion.
I have modified many of the existing drawings and always follow this procedure.
Robert Hanrahan
Weigh Right Automatic Scale Co.
ACE user since 1998
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
