AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Change or update cross reference style
4 REPLIES 4
TRLitsey
980 Views, 4 Replies
I have two schematics of similar machines.  I want to use the half of the drawings from one machine and half the drawing from the other machine.  The cross reference symbols are different styles.  One uses the ‘xx-yy’ format and the other uses a hex symbol with over/under numbering.  Is there a quick way to change the style from one to the other?  Thank you
Please mark as a solution if this works for you, kudos are always welcome
4 REPLIES 4
jalger
in reply to: TRLitsey
Hi TRLitsey,
Without seeing exactly what your trying to do I would suggest the "Swap/Update block" Command.
It should let you swap out one of the styles with little effort. ( just pick the style you want, and run the replace project wide on the style you want to remove.)
If you need any help running the Command just ask,
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
dougmcalexander
Once you add all the drawings to the same project, you can set the cross-reference style in project properties. You must then apply project defaults to all drawings in the project, using shift to select the drawings and right click to fly out the option to apply project defaults. Then perform a cross reference update project wide. Maybe I am misinterpreting your question?
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
drathak
in reply to: dougmcalexander
With the drawings coming from two different projects originally, will the cross references actually find each other?  I guess if all the signal codes match they might.  Interesting situation.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
dougmcalexander
in reply to: drathak
If source and destination codes match, they should connect.  You will probably need to run the Update Signal References utility to sync them.
If the tags match between parent and child the cross references should function.  But you should run Update Crossreferences.  Project-wide update/retag might help.
Doug McAlexander
”Boost
