hello all.
i want to change use iec blocks instead of jic block, but when i follow the steps on help and switch standards at step 6 i have a problem: i cant add the iec standard. how i can do it?
thanks.
NoteAutoCAD Electrical searches for a symbol in the order the folders are listed.
It sounds like you might need to add the IEC library to you computer. This is not installed by default.
Run Change Program from Windows Control Panel and add the IEC libraries.
so my problem is here. how i add the iec?
where exactly address I should go and add iec?
Go to Control Panel and select Uninstall Program.
You will need the Installation disk to proceed.
After the list comes up, Double Click on Autocad Electrical 20## and after the dialog box for that comes up, select Add and Remove Features.
Select what changes you want and wait about 1/2 hour for it to update.
That should do it.
thanks for your helful answer. But during the installation progress i extract my ISO file to virtual disk and install. And now i want to change jic to iec standard but this modify require DVD instalation disk , not virtual disk. I can't burn my ISO file to DVD. Do you have link to downlaod Autocad Electrical 2012 for win 7 64 bits? I've tried to find in Autodesk website but hanve only Autocad Electrical 2012. I need 2012. Can you help me?
Thanks so much
I was able to change the file paths and symbol library from JIC to IEC, but now when I insert a symbol it very large. Larger than the page.
Is there a scaling from inch to metric somewhere?
It sounds like you page is still set to the JIC page size.
To use IEC symbols on a JIC page, you need to scale them down by 25.4 or scale every thing on the page (and the page) up by the same.
To scale the blocks, insert a block from the insert component menu and enter 0.03937 in the schematic scale box at the bottom. Once you insert a block, ACADE will remember the setting for the next insert.
Regards Brad
Brad Coleman, Electrical Draftsman
