Can someone please tell me why I am getting the below image when trying to insert a catalog data from the default catalog? I checked the folder and the default catalog is there. Thanks
Please make sure the path in the wd.env file is correct as well.
The wd.env file can be found in following place if default install:
C:\Users\shouz\Documents\Acade 2014\AeData\
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
I am sharing my network and the AEDATA path is at the top in my support file search path. We are still using 2013 version. Am I doing something wrong here? Thanks.
Below is the screen shot of my env. file for the catalog :
I still can't get my default catalog. Thanks
Your wd.env file looks good, is your wd.env file in the same folder with the Catalogs folder.
By default, the wd.env file should be "..\AeData\wd.env", and the Catalogs folder should be "..\AeData\Catalogs\".
Can you use the following 2 parameters to check if the Catalog path is correct or not?
Here is the result in my machine, they are correct.
Command: !gbl_wd_catmdb_fnam
"C:\\Users\\shouz\\Documents\\AcadE 2013\\AeData\\catalogs\\default_cat.mdb"
Command: !gbl_wd_catalogs
"C:/Users/shouz/Documents/AcadE 2013/AeData/catalogs/"
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
I went ahead and reinstall everything and it seems to be working now.
Is anyone getting the below image when trying to insert terminals? How you fix it?
Pls let me know. Thx
