AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Catalog popup not listing values
1 REPLY 1
214 Views, 1 Reply
I am customizing the catalog setup, and
want to be able to search by different categories other than MFG, TYPE and
RATING. I understand that whatever Access fields are in columns 2,4 and 5
will become queries 1 2 and 3.
When I moved the columns, my first pop-up column wasn't wide enough, so I
altered the width in the wdcat.dcl file, which worked fine. However, the second pop-up
menu consistently no longer pops up, regardless of what table is accessed.
I though all I changed was the column width.
Is there a control somewhere that I am not finding that controls how many
values display in the pop-up list?
1 REPLY 1
We ran across a defect today that may explain... if the Access table column
field name is edited to include an embedded space then its pop list will fail in
the catalog lookup. Did you rename the field to something with a space? If so,
try an underbar.
”Boost
