If you want to see manufacturer and catalog number on a symbol simply edit
the symbol to make the MFG and CAT attributes visible and larger. The
default is Invisible=Yes and 0.01 text size.
wrote in message news:5990507@discussion.autodesk.com...
Are you able to add a catalog number attribute to a symbol so that it
displays the relevant manufacturers on the symbol depending on which part is
chosen from the catalog?
thanks
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
