If I go into my database and do replication on it, I can get the results you
are seeing. I have not tried this without SP2 installed. I have been
trying to find a way to remove the replication option, but I am not an
Access expert and have not done anything at all with replication in years
and even then it was just some playing around with it.
Maybe someone else on here would have an idea of how to remove this from the
database so that you don't need to build a new catalog file. Or maybe go
back to what they backed up, maybe it is OK.
Maybe saving to an older version of Access would work also, but it did not
seem to matter for me, but I am using Access 2007.
Steve
wrote in message news:5709946@discussion.autodesk.com...
The path in the title bar on catalog lookup is correct, so are the paths in
the project settings. I have found that if I switch to the original catalog
file that came with the software it will display the records. Also if I copy
some records out of a table in my catalog and paste it in a working copy of
the original catalog, that table will no longer display records in catalog
lookup. Is my catalog file corrupt maybe. The tables are all labeled
replicated, I think someone ran some kind of backup on that network drive
and after that all the tables were marked replicated. But it was working
like that before installing the service pack. I think I am just gonna have
