AutoCAD Electrical Forum
Catalog Database
3 REPLIES 3
Vulcan1970
758 Views, 3 Replies
Catalog Database
i am wondering if there is a way to edit the way the default cat database shows items in the parts catalog. i want to be ablle to go to my panel layout, icon menu, insert footprint, red light, catalog lookup, and be able to only show the items that i want. My default is set to show AB 30.5mm lights. Is there a way to change this default?
Autocad Electrical 2013
3 REPLIES 3
testsubject
in reply to: Vulcan1970
In the catalog database, there is a table called _LISTBOX_DEF.
Edit this table to select the default items that appear when each different family table is opened.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Vulcan1970
in reply to: testsubject
Thank you for the quick response. I found the table and made the change.
However, It is not showing up. I tried shutting down AE and also tried AEREBUILDDB. I checked the file path and i believe i changed the correct file. Is there a command that is suppose to update this change?
Vulcan1970
I spoke to soon
I typed in the new change in the parts catalog pop up and then the next time i opend it, it was corrected
thank you
”Boost
