You can see invisible attributes by typing ATTDISP and setting it to ON
rather than Normal. You can erase each one then. Although, it sounds like it
is on multiple drawings rarther than one. Was it the Project-wide utilities
with the Remove All wire numbers option selected, that you tried already and
it didn't erase them?
Pat Murnen
wrote in message news:5184790@discussion.autodesk.com...
Ok I get a list that coincides with the scratch database but I still do not
see the wire number. It must be a wire that was assigned a fixed number
hidden and then copied from drawing to drawing. Question is now how do I
remove such a wire number with out erasing and redrawing all the wires.
Apparently the erase wire number feature does not work in this case.
