I am having trouble renaming 2 drawing files in a project. The names I want to use were existing drawings, that I removed from the project. The 2 drawings were the wrong version, and I am trying to put in the correct versions.
Example. I had drawing MyProject-A06.dwg. I removed it from the project using project manager. I then added the drawing I needed, OtherProject-A06.dwg, again, using the project manager. Now, when I try to rename OtherProject-A06.dwg to MyProject-A06.dwg, I get AutoCAD message "Rename Failed" with yellow triangle! and then the entire folder pathname for the file.
For now, I renamed OtherProject-A06.dwg to MyProject-A06a.dwg. I need to get the name corrected however.
I'm guessing that somewhere in the project file, there is some remnent of the original drawing files name that I removed, but I don't know where to look for it or how to fix it. Does anyone know what to do for this?
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Cannot Rename Drawings In a Project
Solved by algerj. Go to Solution.
Hi Midnight412,
By the sounds of it, you merely removed the drawing from the project.
The psychical Drawing Still exists in:
C:\Users\<user Name>\Documents\Acade 2014\AeData\Proj\<your projects name>
You will have to Remove/rename the Drawing in the Project file folder before you can create a new one with the same name.
I hope this helps,
James Alger
One more thing,
If you deleted the drawings before removing them from the project then it will still have a marker at the bottom of the WDP file. (it points to the drawing name)
You can remove the text the points to the specific drawing, and it will remove the link.
James Alger
Overly simplistic and prolly fairly obvious, but AcadE cannot rename a file that is open, either.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
