With your project dialog open, select the "Symbol LIB" button in bottom
left-hand corner of the dialog. On the next dialog check to make sure that
your custom icon menu ".dat" file is listed in the bottom edit box.
"Tom Jandrokovic" wrote in message
news:MPG.1b72ac246cca58ce989681@discussion.autodesk.com...
> I wonder if someone could possibly shed some light on this problem?
> When I click on "Insert Component", the standard icon menu is displayed,
> rather than the custom icon menu that we normally would use.
> I have the following lines in my wd.env file:
> WD_MENU,G:\AutoCAD\Config Files\ACAD2004\cmc_menu.dat
> WD_PMENU,G:\AutoCAD\Config Files\ACAD2004\cmc_pmenu.dat
> At the command line, a query tells me:
> Command: (c:wd_getenv "WD_MENU")
> "g:/autocad/config files/acad2004/cmc_menu.dat"
> yet the default icon menus are displayed.
> If I rename the WD_menu.dat file that exists in
> C:\Documents and Settings\CLJAND\Application Data\Autodesk\AutoCAD
> Electrical 2004\R16.0\enu\Support, I receive the "Cannot Find Menu File
> Definition" error.
> What in world might be wrong here?
> Tom Jandrokovic
> Software/Automation Engineer
> Cleveland Motion Controls
