AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
cannot do "retreive from peer" in different sheet
2 REPLIES 2
217 Views, 2 Replies
retreive from peer mean get the pin number from the 1st coil, it can be done by "NO/NC SETUP" and select the source coil to get the pin for second sets of coil, however lf you wanna to draw the 1st coil in 1st sheet and the second coil in another sheet this command cannot be done because you cannot select/pick the 1st coil, is it any solution for this?
2 REPLIES 2
KevinLi-Autodesk
I think this command is only supported in the current active drawing and do not support across drawings, if you only need the value from the 1st coil in the 1st sheet, you can try to copy the coil in the 1st sheet and paste it on the 2nd sheet then use this command to pick it in the 2nd sheet, then delete it after retrieve is done. But it is not convenient if you have many coils needed to do so.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Perhaps Autodesk aware and find a solution about his matter
”Boost
