Using both 2013 and 2014, when I try to assign the catalog information to the block I'm inserting, I get the following message on the command prompt and nothing happens in the dialog box.
"Error: bad argument type: fixnump: T; error: bad argument type: fixnump: T".
It works correctly in 2011 using the same menus, blocks and catalog dtabase that I am attempting to use in the later versions.
Any Suggestions?
Did you use the migration tools to migrate from one release to the next? There is not enough information in your post to really know what the problem might be, but using 2013 or 2014 to access a 2011 catalog database may be causing the problem.
Lee
No, I didn't use the migration utility. To date, it hasn't been necessary, and we've been using ACADE since 2007.
I think that I've actually tracked the problem to the env file.
The env file we use is hosted on a server, to ensure that everyone is using the same settings. When I open a project that references the exisiting env file I have problems.
I noted that the support path now includes the %WD_LANG% parameter that allows the "/en_us/" folder in the support path.
I've created a new env file in the server location the is specifically for 2014. Seems to work.
