AutoCAD Electrical General Discussion
0 Kudos
Post 1 of 9
Can't find VRT1 from IEC icon menu dat file
1176 Views, 8 Replies
03-13-2012 12:57 PM
I switched the icon menu library to ACE_IEC_menu.dat so that I could use the VRT1 icon in my drawing. But when I use the icon menu and choose VRT1, it says file can't be found. What am I missing in order for AutoCAD to insert the icon into my drawing. I attached a picture of the error.
I found the folders in another location. It's apparently stored in the Autodesk folder shown below.
147 Kudos
Post 2 of 9
Re: Can't find VRT1 from IEC icon menu dat file
03-13-2012 02:15 PM in reply to: jmatt05
You must also set up the project to search the IEC2 or IEC4 (the difference between the two of them is the size of the attributes) folder, so that it can find this VTR1.dwg.
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
0 Kudos
Post 3 of 9
03-14-2012 04:58 AM in reply to: rhesusminus
There is no IEC2 or IEC4 folders. Do I have to install those libraries or are the somewhere else? I've attached a picture of what I have in that folder.
147 Kudos
Post 4 of 9
03-14-2012 05:07 AM in reply to: jmatt05
Hi.
Try going to the control panel in WIndows, and locate AutoCAD Electrical 2012.
Select Change/Uninstall, and select Add or Remove features.
In one of the steps that follows, you should be able to add the IEC symbol libraries as well:
Trond Hasse Lie
0 Kudos
Post 5 of 9
03-14-2012 05:26 AM in reply to: rhesusminus
147 Kudos
Post 6 of 9
03-14-2012 05:53 AM in reply to: jmatt05
That seems to be the location were you installed your downloaded(?) AutoCAD Electrical from. However... Just copy those folders to the same location as your other symbol libraries.
Trond Hasse Lie
0 Kudos
Post 7 of 9
03-14-2012 10:16 AM in reply to: rhesusminus
Ok so I copied it over and got it working. Do you have an issue with icons being really large like shown below? Would you know how to fix this? This component is VRT1.
147 Kudos
Post 8 of 9
03-14-2012 12:34 PM in reply to: jmatt05
All IEC symbols are made in metric units. You'll have to scale them down whem inserting then in a drawing created in imperial units. Try a lower scale factor in the insert component dialog (look at the bottom of this dialog).
Trond Hasse Lie
0 Kudos
Post 9 of 9
03-14-2012 12:37 PM in reply to: rhesusminus
Ok thanks that worked.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
