Hi,Everybody.
I am attaching aword.doc sheet which contain Autocad Question.
Can sombody help me.
Kindly given the correct answer of Attached sheet.
Thanks & Regards
ersidhu
Solved by cbenner. Go to Solution.
May I ask why you don't simply put your question in the forum post itself? Some people may be leary of opening an unknown document like this, for fear of viruses and such. Is there information in the DOC that you cannot post in the forum window?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
