In our cable database we fill in descriptions with the text mm² (ALT code 253). Also if we look in the MDB’s it’s written in that way. But if we ran a report then it is displayed as mm2. or put it as a table inside a schematic drawing then it’s lost.
This happens for example if you run a Cable Summary Report.
Is there a way that we can get mm² in the tables? Because if we modify it manually then it’s possible, but this is too much time consuming.
AutocAD Electrical 2009
Srvpack 2
32-bits
