AutoCAD Electrical General Discussion
*Pat Murnen
Message 21 of 23 (140 Views)
Re: Cable shields - why can't I get it to work?
06-16-2008 08:07 AM in reply to: martin.rule
After looking at the drawing you sent and at the symbols in the iec2 folder
it looks like maybe the attribute name is incorrect on at least the
HS0_21.dwg, HS02_1.dwg, and HS02_2.dwg library symbols. I will log this.
Try changing the library symbol so that the right link attribute is X2LINKR
rather than X8LINKR. Make sure to remove any existing ones from the drawing
you are working on and purge the blocks.
Sorry for any inconvenience,
Pat Murnen
"Pat Murnen" wrote in message
news:5957987@discussion.autodesk.com...
DavidC, can you provide a drawing that you tried to insert this on? Either
post it here or you can send it directly to my email at
pat.murnen@autodesk.com.
Pat Murnen
wrote in message news:5957341@discussion.autodesk.com...
Hi Pat or anyone watching this post,
The problem with the shield insert seems to exist in ACADE 2009
The install is an upgrade from 2008 - since uninstalled.
I had no call to use the shield in 2008 so never picked up on this
Any suggestions what to do first to resolve this? (IEC symbols)
The HW2_ symbols seem to have the left right link tags but the right link
doesn't fill
Thanks DavidC
New Member
knewman
Message 22 of 23 (115 Views)
07-12-2012 11:25 AM in reply to: *Pat Murnen
FYI this problem still exists in ACADE 2012 with block VW02_1T (Cable with shield All 2nd) in the JIC library. I was able to fix it by renaming the X4LINKL and X4LINKR attributes to X1LINKL and X1LINKR. However, making that change caused the TAG2 attribute to move to the last (shield) cable marker block in that linked group (i.e., it hid the TAG2 on the first--leftmost--block and unhid it on the last--rightmost--block). Weird.
tim
Active Member
tim
Message 23 of 23 (68 Views)
01-19-2014 10:15 AM in reply to: knewman
ACADE 2014 and the problem is still there. Renaming the attributes solves the incomplete symbol but the misplaced tag is still an issue.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
