After looking at the drawing you sent and at the symbols in the iec2 folder
it looks like maybe the attribute name is incorrect on at least the
HS0_21.dwg, HS02_1.dwg, and HS02_2.dwg library symbols. I will log this.
Try changing the library symbol so that the right link attribute is X2LINKR
rather than X8LINKR. Make sure to remove any existing ones from the drawing
you are working on and purge the blocks.
Sorry for any inconvenience,
Pat Murnen
"Pat Murnen" wrote in message
news:5957987@discussion.autodesk.com...
DavidC, can you provide a drawing that you tried to insert this on? Either
post it here or you can send it directly to my email at
pat.murnen@autodesk.com.
Pat Murnen
wrote in message news:5957341@discussion.autodesk.com...
Hi Pat or anyone watching this post,
The problem with the shield insert seems to exist in ACADE 2009
The install is an upgrade from 2008 - since uninstalled.
I had no call to use the shield in 2008 so never picked up on this
Any suggestions what to do first to resolve this? (IEC symbols)
The HW2_ symbols seem to have the left right link tags but the right link
doesn't fill
Thanks DavidC
