Hi
Last problem
my multicore is spread over 3 sheets, i am using hd2l_ref to connect them (all the same sigcode)
all works fine
for the cable report to work correctly, i needed to put 1 cable marker on the multicore on each sheet (3 in total in project)
but the audit throws up a duplication cable marker error,
I can ignore the audit error
any advice is great
Steve
Solved by testsubject. Go to Solution.
Therein lies the rub. ACE expects only 1 source/destination pair. I am unsure of how to get around this. It does "allow" you to have 1 source/many destinations, but squawks about it. You might have to ignore this error. Anyone have anything to add??
The number of source & destination objects are equal, i.e. one source has one dedicated destination but not on the same sheet.
Steve
I misread the OP.
I think this will work. Pick one of the cable markers as the parent and on the other drawings, make the other cable markers children.
I tested it and it did not through a cable error....
In the Cable Marker section (Icon Menu/Miscellaneous/Cable Markers) there is a selection for "2+ Child Marker". Use this in the second and third drawings in your package in place of the parent marker you already have. I would just delete the current cable markers and re-insert using the child one and then select the parent cable marker on the first page (assuming the first drawing has the source arrow for the cable.)
Glad I could help!
