AutoCAD Electrical Forum
cable marker duplication - last glitch observed
7 REPLIES 7
Message 1 of 8
Yeletah
427 Views, 7 Replies
Hi
Last problem
my multicore is spread over 3  sheets, i am using hd2l_ref to connect them (all the same sigcode)
all works fine
for the cable report to work correctly, i needed to put 1 cable marker on the multicore on each sheet (3 in total in project)
but the audit throws up a duplication cable marker error,
I can ignore the audit error
any advice is great
Steve
7 REPLIES 7
Message 2 of 8
testsubject
in reply to: Yeletah
Therein lies the rub. ACE expects only 1 source/destination pair. I am unsure of how to get around this. It does "allow" you to have 1 source/many destinations, but squawks about it. You might have to ignore this error. Anyone have anything to add??
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 3 of 8
Yeletah
The number of source & destination objects are equal, i.e. one source has one dedicated destination but not on the same sheet.
Steve
Message 4 of 8
testsubject
I misread the OP.
I think this will work. Pick one of the cable markers as the parent and on the other drawings, make the other cable markers children.
I tested it and it did not through a cable error....
Bob Hanrahan
Ace User since 1998
Message 5 of 8
Yeletah
How did you make a parent cable marker a child?
Message 6 of 8
testsubject
In the Cable Marker section (Icon Menu/Miscellaneous/Cable Markers) there is a selection for "2+ Child Marker". Use this in the second and third drawings in your package in place of the parent marker you already have. I would just delete the current cable markers and re-insert using the child one and then select the parent cable marker on the first page (assuming the first drawing has the source arrow for the cable.)
Bob Hanrahan
Ace User since 1998
Message 7 of 8
Yeletah
Success!
Smiley Happy
Steve
Message 8 of 8
testsubject
Glad I could help!
Bob Hanrahan
Ace User since 1998
”Boost
