AutoCAD Electrical Forum
Cable Fanout Report
0 REPLIES 0
Message 1 of 1
kalpakiotis
282 Views, 0 Replies
Cable Fanout Report
I have been using AutoCAD Electrical for a few years now and came across an example of wiring that I can't figure out how to get to show up in the From/To report.  In this case I am using a cable that has a connector on one side and the other end is loose wire.  Is there a way using the Fanin/Fanout or some other tool to have the report show each wire connected to the connector on Block B and its pin location on Block A in the attached image?
ex. Wire 1: Block A Pin 1   -->   Block B Pin 1
     Wire 2: Block A Pin 2   -->   Block B Pin 1
Currently, ACE is showing the fan out as a single wire connection when I run the report.
     Wire 2: Block B Pin 1   -->   Block B Pin 1
Thanks in advance,
Vasili
0 REPLIES 0
”Boost
