I put a triple fuseholder 018FU1 in page 18 as you could see in the attachment,
when I try to put the fuseholder in cabinet layout , acade tell me to insert 3 times the 018FU1.
If I check in the report BOM I find one fuseholder, this is correct.
Could someone help me?
thanks
Massimo
Was the block for the fuseholder a 3-phase block, or did you insert three fuse holders and connect them manually with a line.
I resolved my problem with a creation of new block of 3phase fuseholder, the 3 fase fuseholder of acade gave me the problem.
Massimo
