This routine appears to include for reference only dwg's when ran project wide.
Is there another command that runs reports "drawing wide" at the command line?
EDIT:
It appears by switching "for reference only" in acedrawingprops it then updates somthing that allows the ace_auto_rpt to update which drawings to run on. Currently I am changing the wdp through software and then calling autocad through a batch to rn a script, but it never seems to see the reflected changes in what is "for reference only". I even included an aerebuild command and ace_wdp_reread. Nothing seems to work in refreshing it except manually in drawing properties . . .
Any thoughts on how to do this in a script???
Solved by crosby.109. Go to Solution.
I try to do as much as I can outside of LISP routines, so I was able to solve this by just throwing an atomic bomb and deleteing the scratch database for that particular project every time there is an update.
