AutoCAD Electrical Forum
c:ace_auto_rpt
2 REPLIES 2
crosby.109
581 Views, 2 Replies
c:ace_auto_rpt
This routine appears to include for reference only dwg's when ran project wide.
Is there another command that runs reports "drawing wide" at the command line?
EDIT:
It appears by switching "for reference only" in acedrawingprops it then updates somthing that allows the ace_auto_rpt to update which drawings to run on.  Currently I am changing the wdp through software and then calling autocad through a batch to rn a script, but it never seems to see the reflected changes in what is "for reference only".  I even included an aerebuild command and ace_wdp_reread.  Nothing seems to work in refreshing it except manually in drawing properties . . .
Any thoughts on how to do this in a script???
Tags (5)
2 REPLIES 2
rhesusminus
in reply to: crosby.109
Have a look at the following variables before/after changing the "for reference only" in the drawing properties:
GBL_WD_PROJ_D2LST
GBL_WD_PRJ_IXLST
GBL_WD_PRJ_IXLST_STAMP
You might have to edit these to match what you do in the WDP-file.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
crosby.109
in reply to: rhesusminus
I try to do as much as I can outside of LISP routines, so I was able to solve this by just throwing an atomic bomb and deleteing the scratch database for that particular project every time there is an update.
”Boost
