Command «Panel List» dialog opens «Panel Components ...», in which the two buttons «Reload» and «Pick File» perform the same function - to open up a dialog box «Panel Layout List ...». Perhaps the functions of these buttons are different?
Hi GalaShkina,
You are correct the buttons do the same thing now.
(I think it has done the same thing for the last few releases... I recall it working in 2010)
At one point Pick file started the Browse Command directly.
Now it just brings you back to the same starter screen where you can reload the project or select a different project database to insert from, using "Browse".
Its very useful if you are building a similar Project and you want to start with the panel instead of the schematic.
(for Quoting purposes usually)
I hope this helps,
James Alger
Thank you very much, James!
I have tested buttons again, they do work differently. The button "Reload" marks existing components, and the button "Pick file" no.
