AE 2012 SP1 on XP SP3 32bit
Have an issue where project wide update of signal cross-references / wire number is failing or incomplete.
Symptoms
-project wide update of signal cross references does not complete
-some signal xrefs show as hexadecimal codes instead of proper numbers
-you can see a sample in the attachment
Conjecture:
I think AE takes several "passes" through the project to do a complete signal xref update.
It like lt sticks temporary codes in on one of the early passes.
At some point in the process it fails or completes prematurely, leaving the temporary codes in place
For your issue, can you give us a sample project with some drawings which can reproduce the issue?
Then we can check what is the problem there. as we can't reproduce the issue in our Demo Project.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
